跳转到主内容
加入维修社区 - 创建账户
于2015年十月26日上市的第四代Surface Pro平板电脑。
Touch Screen horizontal dead zone
Hello I have followed the I fixit instructions as well as others and replaced my faulty sp4 screen with a brand new LG sp5 screen (screen displays perfect) I have also replaced the LBoard (ntrig) with a new one. When I'm in Windows 10 I have a 2 inch horizontal dead zone about 1/4 of an inch down from the top of the screen. Neither finger or pen work in this area,
If I boot in uefi it demonstrates the same behaviour,
Note1: I have also fitted my original ntrig (Lboard) aswell and have the same problem.
Note2: I have run all diagnostic test in surface Diagnostics, done fresh restore on Windows,
Note3: I have not yet replaced the digitalizer cable.
Is it possible I have a defective screen or digitalizer cable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
mrkeshin88 since this "2 inch horizontal dead zone about 1/4 of an inch down from the top of the screen" does not change, and it is consistent within and without your OS, it appears as if you have a failed digitizer. You would have to replace it and recheck
这个答案有帮助吗?
得分 0
1条评论:
That's my thoughts, I have contacted the supplier as this is a brand new screen I have purchased and installed
完成的
添加一条评论
I am experiencing the same issue; it appears to be a problem with the touch digitizer. Could you kindly provide any links where I can purchase a new digitizer for the Surface Pro 5th generation model?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mrkeshin88 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 782
