跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 840 G3 的维修信息。这款惠普笔记本电脑专为企业应用而设计。
How To Fix Dark Screen Laptop?
How To Fix HP Black Screen - Computer Starts But No Display - Screen Not Working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
hp 840g3 screen backlight problem
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Connect an external monitor to the laptop's DP or vga port and check if there's a display on it.
Toggle the F4 key to switch between the laptop screen on only, the external monitor on only or both on together.
If there is a display on the external monitor, try shining a flashlight at an angle close to the laptop screen and check if you can see any images.
They will be very faint if they are there to be seen so trying this in a darkened room may help.
If you can see images then there's a backlight problem with the screen.
This could be due to a faulty backlight power circuit, faulty or loose video cable or a faulty display.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
RIDI qili 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 25
总计 1,095
