跳转到主内容
加入维修社区 - 创建账户
Bajaj Discover 是 Bajaj Auto 旗下的摩托车品牌。目前 Discover 有四种型号:Discover 100 DTS-Si、Discover 125 DTS-i、Discover 125ST 和 Discover 150 DTS-i。
It can't start
My motor bike is not starting
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 18
13条评论
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
由完成的
My motor cycle not start
由完成的
Bettry charging
Palag problem
Indicetar chlu
由完成的
البوجية لا تعطي كهرباء قوي
Translation Arabic - English
The spark plug does not give off strong electricity
由完成的
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ما نوع الدراجة وموديلها؟ ما حجم المحرك؟ ما العام؟ ماذا فحصت؟
由完成的
显示更多的8条评论
添加一条评论
4个答案
已选择的解决方案
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
  1. Check the battery: Make sure the battery is fully charged and that all connections are clean and tight. If the battery is old or weak, it may need to be replaced.
  2. Check the fuel: Make sure there is enough fuel in the tank and that the fuel valve is turned on. If the fuel is old or contaminated, it may need to be drained and replaced.
  3. Check the spark plug: Make sure the spark plug is clean and properly gapped. If it is fouled or damaged, it may need to be replaced.
  4. Check the air filter: Make sure the air filter is clean and not clogged. A dirty air filter can restrict airflow to the engine and cause starting problems.
  5. Check the carburetor: Make sure the carburetor is clean and functioning properly. If it is dirty or clogged, it may need to be cleaned or rebuilt.
  6. Check the ignition system: Make sure the ignition system is working properly. This includes checking the ignition coil, CDI unit, and other components.
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
这个答案有帮助吗?
得分 7
添加一条评论
Try kick start maybe your battery is worn out
这个答案有帮助吗?
得分 3
添加一条评论
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
这个答案有帮助吗?
得分 0
添加一条评论
Start with the basics 👍
  • Check battery (most common, does it crank?)
  • Fuel on + not empty
  • Kill switch off
  • Listen: no crank = battery/starter, cranks but no start = fuel/spark issue
If it’s been sitting, fuel or plugs are usually the culprit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geoffrey Ouko 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 197
总计 8,250
