跳转到主内容
2022 model in 14' and 16' inch
4 个问题 查看全部
help me buy the right screw bit
Hi,
i was trying to replace the thermal paste on my IdeaPad 5 Pro 16ACH6. i did unscrew the screws holding the back cover and the fans using available screw bits but the screws holding the heat sink didn't come off, which screw bit should i use for it? the hardware maintenance manual says its a M1.6 x L1.7 screw, what does that mean?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@sneed M1.6 x L1.7 means that the screw has a metric thread, is 1.6mm in diameter and that it is 1.7mm in length (measured from the bottom of the screwhead to the end of the threaded part). It is not related to what tool you need for removal. That is depended on the screwhead. According to the illustration in the maintenance guide, it is a PHillips Screw head. I suggest that you get a good toolset, at least something like this Mako Driver Kit - 64 Precision Bits Screws like the one you are working on, commonly use threadlocker to keep them secure. That means you need a good fitting screwdriver and apply some downward force while trying to turn the screw.
Mako Driver Kit - 64 Precision Bits图片
产品
$39.95
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sneed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 373
