跳转到主内容
加入维修社区 - 创建账户
2016年3月发布的4英寸iPhone,硬件规格与iPhone 6S相似。提供银色、深空灰色、金色或玫瑰金色,存储容量有16/32/64/128 GB可选。型号:A1662和A1723
Weird boot loop behaviour
Hi there,
I am trying to repair a first generation iPhone SE, and I struggle to make sense of its behaviour.
Even though the battery is most likely completely drained, when I plug it it instantly shows the battery charging image, and after only 3 seconds (maybe more, but no more than 10 seconds) it starts to boot, meaning the Apple logo appears. The Apple logo stays for a very short time too, no more than 10 seconds, and then the screen goes black, and the loop instantly starts again: battery charging image for a few seconds, Apple logo for a few seconds, back to black, etc. It can go on that way for hours.
It looks like a battery issue, but several things seem weird to me:
  • first off, the previous owner told me the problem started after a fall. Indeed the screen is badly damaged. I don't see the connection between a fall and a battery issue
  • second, if that was a battery issue, I don't see why it would start to boot prematurely
I tried disconnecting the screen and the battery and reconnecting everything, no change.
I don't have a spare battery to test, and would like to know whether that is the problem before ordering one.
Would anyone know what this is about?
Thanks a log in advance for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If it still has the apple battery then replace it. Cost nothing nowadays. If after fitting the new battery and it still has the issue then connect the screen but NOT the front camera, ear speaker cable then try it. If it boots then you need a new ribbon. Again, cheap. Or try connecting the old screen only without ear speaker ribbon then plug the charger in. Good luck.
这个答案有帮助吗?
得分 2
7条评论:
Thanks a lot for the answer! I'll try disconnecting the ear speaker ribbon and keep the current battery, and if that fails I'll buy a new battery. Just to make sure I understand: it's the same cable for the front camera and the ear speaker? It's labeled "front-facing camera and sensor cable" in the iFixit guide, right?
Thanks again very much!
由完成的 分享
@John Dupont yes, front camera, ear speaker cable.
由完成的 分享
So I tried unplugging the front camera cable, left phone open, plugged it in, same exact behaviour. I guess I'll buy a new battery then. Thanks a lot for the help!
由完成的 分享
@John Dupont did you have the charger plugged in as well?
由完成的 分享
Sorry I didn't see your comment earlier. Yes I had the charger plugged in. Anyway if the charger is not plugged in, nothing happens at all
由完成的 分享
显示更多的2条评论
添加一条评论
Try to force restart by holding the up and release and hold down and release and the hold power off until you see apple logo
这个答案有帮助吗?
得分 0
2条评论:
Jelly bean, thats for new phones. The first se you hold power and the home button together until the apple logo appears.
由完成的 分享
Thanks a lot for the answer! I forgot to mention that I already tried hard resets, unfortunately it didn't change anything
由完成的 分享
添加一条评论
添加你的答案
John Dupont 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 37
过去 30 天: 114
总计 3,374
