跳转到主内容
加入维修社区 - 创建账户
Dyson V6 Absolute 是一款于 2014 年 9 月发布的无线、无尘袋吸尘器,带有可捕获过敏原的 HEPA 过滤系统。它适用于所有地板类型,重量为 5 磅。型号为 SV09。
Why after charging and after using Max function it stops?
Dyson V6 (SV05).
I charge the Dyson. If I start it using the max button it stops in less than a minute. Then I plug it and press the button for 20secs as advised in this group and with the MAX function it stops working fast but if I turn the MAX off it works for a while? Do I need to change the battery? They are quite expensive. Thanks for your help
Carla
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like a weak battery. The Max function is powerful so it pulls more amps, which reduces the voltage the battery sends to the motor. Not enough voltage stops the motor. Probably the regular ( non Max) stay above the minimum voltage so it stays running.
This battery repair can help you.
戴森 Dyson v6 Absolute 电池更换
这个答案有帮助吗?
得分 0
1条评论:
Thanks a lot for your answer. The instructions are great. The problem is batteries are so expensive. But at least I know why it is happening. Regards. Carla
由完成的
添加一条评论
添加你的答案
Carla 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 498
