跳转到主内容
加入维修社区 - 创建账户
发布于2013年11月22日的微软第三代Xbox游戏主机。
Xbox one wireless card component missing
I have a xbox one wireless card model 1525 with 2 missing components. It is very hard in my country to find or import (expensive) console spares.
Can someone help me identify these components. 1 is the signal line so might be an inductor or resistor, and 2 probably is a capacitor as one pad is ground. I might be wrong with the component location (as there are pads for 4 components), only 2 are populated is what I understood from photos on the internet. Thanks.
https://ibb.co/vvvYNxC
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@jetuaime81, Taking a look online at some photos of other cards of the same model they are also missing those components. I wold consider attempting to get a different card entirely. Try eBay and look for free shipping ones if you are worried about shipping cost. Hope this helps!
完成的
Sad. This happened when I opened to clean the xbox. The card placement is really sick, can easily damage when opening. The controller drops connection even at 0.5m distance, but it does connect. Perfect to garbage. I did as old turkey said took out two components near another plug and measure, but i couldnt get a good reading on both. I tried resistance and capacitance in my meter. I ended up shorting the signal line (number 1 in the photo). For now it works, i dont know if will hurt something.
完成的
添加一条评论
1个答案
已选择的解决方案
h. p not sure which Country you are located in but I do get that there maybe issues with importing electronics etc. At this time, besides trying to get a new board, I would measure the components around Con1 can Con 3 since they do appear of same size and looks like, may even have the same function. Replace your missing components with those similar components and give it a try. BTW schematics are not available, so you really would need somebody figuring it out on their Xbox and then letting us know.
这个答案有帮助吗?
得分 0
4条评论:
That was a great idea. Simple but functional. I didn't have the brains to think that way. And i live in India, AliExpress and many Chinese apps are banned. And anything coming from china (which is almost everything) gets caught up in customs and is a big hassle for individuals. I believe business people don't face this issue as we still have Chinese products in market, and it's legal.
But, i could not get a valid reading off the components i removed. What i thought was resistor or inductor, was showing 'open' and what i thought was capacitor was showing 0 ohms in resistor. I tired both resistance and capacitance mode, no valid reading. I just ended up shorting the signal line going to the antenna terminal. It works for now, but i dont know if it will hurt the card or maybe even the xbox in long use. Thanks
完成的
@jetuaime81 Big Business stinks, politicians stink and borders stink. Anyhow, if you need one I am sure we can arrange a private mail. Repair is War on Entropy
完成的
Thanks for the offer. Seems to be working. I have used like 1 hr continuously no drops.
完成的
@jetuaime81 AWESOME. Best of luck to you and enjoy your Xbox
完成的
添加一条评论
添加你的答案
h. p 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 330
