跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
163 个问题 查看全部
Can I fix a burned Pcb Board caused By OverVoltage?
I got an Xbox one controller model :1708 and The pcb of the buttom Board is burned around The U1 and the D23 and C7 C6 R17 R20 it is Completly Burned Can I rebuild It Using The Cu thine Cabels using the Diagram and most importan Can I fix or no And thanks Befor .
Note : The prewies owner tell me that he put it into a bad quality phone charger so it might and over voltage via USB caused all that .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
AbdelKarim Lakehal that is some really impressive damage. I will never say it can't be fixed but there will be plenty of obstacles. First your pads and traces are pretty much gone. Second you will need a list of the components and a schematic to see what goes where. You can get some from pictures like this
and some good information from here as well. That will help you find some of the traces but not all of them. Ultimately it's a big job and it might be more economical just replacing the board with one from here Xbox One S Controller (1708) Motherboard
Keep the one you have and work on it at your time. Who knows, you may just succeed. After all, Repair is War on Entropy!
Xbox One S Controller (1708) Motherboard图片
产品
$14.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
AbdelKarim Lakehal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 188
