Transmission has no up shift
No up shift from second gear
Is it an automatic? Most likely it's the Auto Trans Computer. A common problem throughout the 1990's built models. I've personally repaired thousands. Problem often starts with electrolytic capacitors and you can smell it. Leaking / exploding ones often pop the uP chip. Can also be the sensor, but you will need to measure to see if it's switching.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 30
总计 521
Hi,
What is the year model of the vehicle?
由 jayeff 完成的
