跳转到主内容
加入维修社区 - 创建账户
Fitbit Charge 5 是于 2021 年 8 月 25 日发布的健身追踪器。它增加了心电图(ECG)传感器、用于测量手腕汗液的皮肤电活动(EDA)传感器,以及彩色 AMOLED 显示屏。
Fitbit charge 5 screen blank
There is no display on my charge 5... the screen is blank but I know it's working through phone apps
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
do you mean the screen turns on but it s blank or did you mean the screen dosen't turn on whatsoever?
完成的
Yes. From the phone app, I can see it works.. just the screen remains blank
完成的
添加一条评论
1个答案
If your display is not appearing in any way; when you plug in the charger are you getting any vibrate pulse signal from the tap-tic engine? If the display is in question the first test is plugging into known working charge cable, and test for charge initiation pulse on connecting charger.
You first should try hard reset using charge cable. You should see or feel vibration pulse when charge cycle is initiated. If you don't feel momentary vibrate pulse when connecting charger; but you are certain it is active in the app.... really this could indicate defective display! Curiosity, I would think if as you say the fitbit is active in the app, are you getting any kind of indication of data reporting> In your app I would also check notifications are not turned off!
If you decide to replace display; I recommend using hot air with maximum heat temp at 130c approximately 45 seconds preheating do not repeatedly reheat or risk battery damage or main board damage.
If tap-tic is defective I don't think it will power on regardless of known working display. For the cost if you replace display screen, you should replace battery by default. You must however be very gentle handling micro components particularly it can be extremely difficult when reconnecting delicate ribbon cables. Not everyone has digital microscope camera because I inspect all connectors prior to any reassembly, and you may need a decent holder fixture when attempting to reconnect battery in particular.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sazali 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 58
总计 1,221
