跳转到主内容
加入维修社区 - 创建账户
适用于配备 CDMA 3G 蜂窝网络(Verizon)的第二代 Apple iPad 的维修指南、拆解和故障排除信息,可选 16、32 或 64 GB 存储空间。搭载双核 A5 处理器。于 2011 年 3 月发布。通过型号 A1397 识别。维修需要加热并小心撬开。
Transfer Data From Dead Logic Board?
Hi all,
This is my first question, so please bear with me as I figure this out.
I have a iPad 2 CDMA (64GB) that had the battery swell up and explode (no one was injured other then the iPad itself), and it killed the screen, case, and the logic board. I bought the same model on eBay to try and swap the parts, and after I tested individual components with the new ones, I know that the logic board is dead, although I did get a relevant current draw when the power button is pressed. .
Since I know the logic board is dead, I used the iPad 2 Teardown Guide to locate the NAND flash chips, and attempt to transfer them to the new logic board. The only issue is that I ripped a few PCB pads during the de-soldering process of the original chip on the new logic board.
Is it possible to fix the ripped traces, or do I need another new logic board? Also, is this idea to recover the data even feasible? Since I haven't touched the original logic board with the data yet, those chips are still soldered on, so I obviously need a few tips on removing those as well.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
It's deceased, I wouldn't waste your time.
由完成的
添加一条评论
2个答案
已选择的解决方案
It's not possible to recover data this way by replacing just the NAND chips. The data on them are encrypted with keys only known to the CPU, you need to migrate the CPU onto a new board as well.
Fixing ripped pads under the NAND chips or on the board is possible.
https://www.bilibili.com/video/BV1Ci4y1R...
https://www.bilibili.com/video/BV1vW411C...
这个答案有帮助吗?
得分 3
1条评论:
Great, Thanks! One more thing though. Do you have any tips with the hot air station so this doesn’t happen again? My previous settings were 400C at 50% blower speed. That seemed to be the minimum to get the chip to come off, so I must not be doing something correctly.
由完成的
添加一条评论
I think I got it, but now the iPad is boot-looping. Any suggestions? Thanks.
Edit: I just left the iPad sitting there for an hour or so, and it finally booted up. Thanks for the help!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
archaic_fixer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 26
总计 1,600
