跳转到主内容
加入维修社区 - 创建账户
Apple 第六代 12.9 英寸 iPad Pro 的维修指南和拆卸信息。2022 年 10 月 18 日发布。
How many NAND in each storage?
In various storage capacity specifications, how many NAND particles are there?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Apple doesn't add more chips to the board to increase the internal storage; instead they use a single chip that comes in different amounts of storage, from 128GB up to 2TB. So if you're thinking of increasing the disk storage on your iPad, you can't just add another chip; you have to remove the existing one, reball the circuit board and solder a new one on. Unless you're experienced at working with BGA components and microsoldering and have the necessary equipment, that's a job best left to professionals.
Does that answer your question, or were you referring to something else when you used the term "particles"?
这个答案有帮助吗?
得分 3
2条评论:
Thank you for replying this question. What I care about is the internal storage read and write speed. If 256GB uses two NANDs, the read and write speed will be faster than one.
完成的
@wa0327 - Yes that would be correct! Interleaving between them
完成的
添加一条评论
If you look at the iFixit teardown you’ll see two Flash chip locations so depending on the storage you bought one or two chips will be installed
Reference: 12.9” iPad Pro 2020 Teardown: What does the LiDAR scanner look like?
这个答案有帮助吗?
得分 1
7条评论:
My Pad Pro is 2022 M2 12.9" 256GB, but the reference you provided is 2020.
完成的
@wa0327 - it’s the same layout! Just like how the MacBook Pro’s have a max of two Flash chips. In your case it’s a single chip.
完成的
Thank you for your replying Dan.
so, 128GB and 256GB both are single NAND chip, right?
完成的
@wa0327 - What is your concern here? The number of Flash cells doesn’t change because Apple used one or two chips.
完成的
Thank you for your replying, Dan. In order to get the fastest r/w speed, I would like to choose that model which has two chips.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
wa0327 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 1,449
