LG TV has weird flickering blue cast on picture
Recently, my LG49UH610T 4K TV started flickering - it isn't the backlight but one of the colours flickering on and off, leaving the screen with a mostly blue colour.
This flickers on and off constantly (but these days it is mostly blueish)
Weirdly, there is a narrow stripe at the top of the screen that is still the right colours:
I have already tried reattaching all the ribbon cables on the boards, and then bought a T-Con board off e-bay but that didn't fix it (actually, maybe it made it worse, so perhaps it was a dud). I then replaced the controller board but that made no difference.
My question then is what to try next - should I get another T-Con board and hope that it works? Or is it likely to be something else going on?
Edit - adding some photos of the boards.
6870-584B T-CON board
EAX66943504 main controller
EAX66923201 Power supply board
Overall arrangement:
Closeup of T-CON board
Connection to screen
Update 1 Mar 2023
After replacing the T_CON board, the screen is not flickering, however the colours remain distorted.
There is a narrow strip along the top of the screen which is uncorrupted
Update 2 Mar
Here is the screen when removing one of the pair of ribbon cables coming out of the T-CON board.
1 Removing the cable on the left
2 Removing the cable on the right
3条评论
We have this issue.. we are not at all clued up or tech savvy.. is there a way we can get this fixed? Or should we just buy a new TV?
由 Emily 完成的
@emily24361 it will depend on exactly what issues your TV has. Let us know the exact issues, the exact model number and the make for your TV. The good thing is that you do not have to be to tech savvy for as long as you don't mind taking some directions (yes, sometimes those are confusing) and all you most commonly need is a couple of hand tools and maybe a multi meter. No worries, we will always show you how to use it and where to measure etc.
由 oldturkey03 完成的
Aw thank you so much.. It’s literally the exact same issue. The TV will work for a few minutes then start glitching with a blue tint.. then it will work again for a while then it does it a lot.
The make is LG webOS TV UJ634V
I have a video of the TV issue if you need me to send it ?
Thank you so much
由 Emily 完成的
