跳转到主内容
The Asus VC239H is an entry-level IPS monitor. Supports 1920x1080 resolution (full HD). First available on Amazon in 2015. Model number: VC239H.
8 个问题 查看全部
Backlight turns on in standby, and turns off then starts again
Hi, on my screen the backlight goes on during sleep, then goes off, then starts again, Asus made me do the hard reset but didn't work.
Here's the thing, while it's in standby, the panel turns on, but no display, just the panel glowing, then turns off again.
No problem to wake up, other than that it works normally.
Tested on my Windows 10 pc and a Mac mini.
THANKS
on the image: from top to bottom, standby screen off, backlight on, blue screen no signal, standby screen off (and a few minutes later it starts again)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@yeantbron That looks like a signal issue. try a different video input source for this monitor and see if it behaves different. If it does not, it is your computer settings. If the monitor does behave the same on a different video input, it's time to open it up and check the main board. Try a different input cable as well (if you are using HDMI input)
Key board refers to the ribbon cable from the button bar to the main board. Careful so you do not tear it. The VC and the S should come apart very similar. Check this video for more info on how to get into it.
这个答案有帮助吗?
得分 1
3条评论:
Hi and thank you, it does on a windows pc, and a mac mini m1, 2 different inputs.
it didn't do it before, happened suddenly.
完成的
@yeantbron You are connecting via HDMI? Tried a different cable? If you do not connect via HDMI, it's time to open it up and to take a look at the main board.
完成的
mac mini on hdmi, windows on dvi.
what to look for on the mainboard?
完成的
添加一条评论
添加你的答案
Monard Frederic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 142
