跳转到主内容
加入维修社区 - 创建账户
第四代 Nissan Altima(底盘代号 L32A)于 2006 年 4 月 12 日在纽约车展上正式发布。它是首款使用更紧凑的 Nissan D 平台打造的车型,采用了全新的前悬挂和升级后的后悬挂。
07 Nissan Altima Acceleration issue
My Altima has 118k miles, was jerking and hesitant when going into drive and reverse, so I parked it. It had a lean code p171 and p300 misfire code so i changed spark plugs and coils, valve cover and gasket, MAF, cleaned throttle body and checked all the fuses. It still does not accelerate, but the RPMs will go high (past 4k) until i let off gas pedal. Goes into all gears just fine, reverse has no issues now, but when i put in drive it feels like its in limp mode. Checked the alternator and its fine, also car has a new battery too. Im at a loss. I still owe $4k on this car and was quoted $2k for a used installed tranny. I really need help!!! Oh i had a TPS code and a throttle actuator code come up 2101, 123 & 223 then realized I had a loose sensor on the throttle body. I cleared the codes and check engine light went off but still doing it. Please Help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you sure its not in limp mode? Also it sound like the auto transmission may be slipping.!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin Shepherd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 315
