跳转到主内容
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
202 个问题 查看全部
Video output distorted and broken fan pins
my PS2 fat series is SCPH-39006. The video output is distorted although audio output is fine. Im planning to fix it myself as i do have quite a handful of soldering experience and i know the basics of hardware stuff and i do have all the equipments to do so. so i thought this would be a good experience. But once i open it i realized i have no idea what im doing and in the process of opening it and trying to get the fan off it appears to broke off. My question is
  1. Where do i start looking or begin with trying to fix the video issues?
  2. Can i just solder back the fan? It will be a pain to remove later but if it works then it works. But if someone have another idea that would be great
  3. Here are pictures of the motherboard
Picture of broken fan pin thingy (my english isnt great)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@raygamerx that is what I would try for as longs as the traces are still good and nothing else ripped off. As for your Video, looks like this board has gone through some heavy mods. That will make it more difficult to troubleshoot and fix. You do want to check all of those soldered wires and check the connections. Make sure none of them is either disconnected, corroded or causes a short anywhere.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 183
