跳转到主内容
Cursor stuck in the upper left corner
I just replaced the logic board and optical drive and when I boot up the mouse pad does not work. What should I check 1st?
Update
The built in track pad is not working. I am checking the connection now. I was hoping to find out which connection is the likely problem.
thanks for the help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Do you mean you're running a USB mouse or the in-built trackpad on the keyboard area? If it's USB the check ports externally for dirt/bent pins and for solder crack internally. If it's the trackpad and you had no previous prioblems then you should recheck your connection there.
这个答案有帮助吗?
得分 4
1条评论:
Reseat the keyboard connector making sure you haven't bent over any pins on the connector: PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard Replacement
完成的
添加一条评论
The 4 pins are straight and connector seems fine. Yet no track pad working yet.
USB mouse does work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John SS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 736
