跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
122 个问题 查看全部
If HDMIs are unplugged they won't display again until restart
Using two monitors both plugged into gtx 750ti. If either HDMIs are unplugged while the PC is on, they will not display again until I restart the PC.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @bkc2k,
Why are you unplugging them if the PC is on?
You can end up causing electrical damage to the HDMI controllers if you're not careful as there's power on the leads. It's always safer to have both devices, PC and monitor powered off when unplugging/plugging HDMI cables
If you must do this for whatever reason, then try pressing Ctrl + Shift + Win + B key (all together) to restart the graphics drivers.
这个答案有帮助吗?
得分 1
1条评论:
I'm not unplugging them they're just loose due to age and if the computer gets bumped they will lose connection. Doesn't happen often but pretty annoying when it does. I will test tomorrow to see if your tip works, thank you!
完成的
添加一条评论
添加你的答案
Brady Collins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 22
