跳转到主内容
加入维修社区 - 创建账户
Zenbook Prime UX31A 的 Windows 8 触屏兼容版本
possible ways for upgrading the RAM.
Where can I find the compatible motherboards for ASUS UX31xxx models?
I have UX31E, already upgraded the SSD via an adapter but I'm trying to understand the possible ways for upgrading the RAM.
Thanks in advance.
Update (01/30/2023)
Could you find any solutions for upgrading the soldered RAM?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@desideroali, On boards with soldered RAM, it’s only possible to “replace” with high level board work (micro soldering).
This is not a DIY task. It requires a lot of skill, appropriate tools / equipment, and a LOT of patience.
这个答案有帮助吗?
得分 2
2条评论:
Thank you.
And what is your suggestion for accomplishing this? Any suggestions for repairshops or compatible hardware?
And even if this is done for UX31E, is the motherboard compatible with 8GB RAM?
由完成的
@desideroali A reputable micro soldering shop should be able to do it, but be prepared to pay a fair bit for the job.
As for compatibility, all information I’ve found on the UX31E says it’s a maximum of 4GB. It’s not to say it isn’t possible, but unlikely.
由完成的
添加一条评论
添加你的答案
desideroali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 1,640
