跳转到主内容
捷威所制造的台式机的支持界面。 现在捷威被宏碁的子公司,现在捷威所有新的产品都是宏碁公司旗下的产品。
40 个问题 查看全部
no monitor or visual display
gt4010 is the gateway pc
computer boots but no display , ive used several monitors , and still nothing i have a repair disc , any tricks ?
Update (01/29/2023)
no video card , i just hooked up other monitors and cables , to make sure it wasn't one of those .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
@do you use a video card or are you using the integrated video card? What have you checked on your computer? Just to verify, your computer is a Gateway 420GR
完成的
@dapose it's all good, no worries:-) Let's see what we can find out.
完成的
hopefully the PC guru's like @aactech or @jayeff can assist you with this.
完成的
@dapose,
Are you sure that it is booting up e.g. Windows welcome sound etc?
The 420GR has integrated graphics in the CPU therefore it may be failing to POST.
完成的
添加一条评论
1个答案
最有帮助的答案
As far as I know this Gateway GT4010 does not have integrated graphics with the Athlon 64 CPU so you will need a video card.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
randall 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 71
