跳转到主内容
加入维修社区 - 创建账户
Apple's successor to the 30-pin dock connector. This cable has been bundled with most Apple mobile products since 2012-2021
USB-C to lightning wiring diagram
Hello iFixers 🙌
I have two broken Apple Lightning cables. One is a USB to Lightning and the other one is USB-C to Lightning.
I'm more or less ok with the first one and it's wiring diagram - it has 4 wires just like the new replacement connectors I got from AliExpress 😁
However with a USB-C to Lightning I feel way less confident - this one has an additional blue wire and here I need your help - maybe someone could share a proper wiring diagram for this case?
Thanks in advance 🙏
P.S.:here are the pics of the new connector
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
5条评论
@insympathy can you post an image of the replacement connector? For now what I have is
Red <==> Positive
White<==> D-
Green<==> D+
Blue<==> Listed as "CC" (maybe sensor wire for Apple's authentication IC (2V?)
完成的
Hey 👋 thanks for answering 👍
I added pics of the new connector to the original post because I fall led to find a way to add pics to the comments
完成的
@insympathy you can't -) Pictures can only be added to answers and question. You did the right thing :-)
完成的
@insympathy looks like that connector doesn't have the connection needed for the blue CC line. You could try and solder the four cables without the blue one and see what happens. I thinks your Apple device may not like it because it can't verify that this is the "right" cable.
完成的
Did this work with the usb-c cable?
Because i used to customize the cables with paracord to make the more durable, but never did manage to venture to the usb-c ones.
完成的
添加一条评论
1个答案
已选择的解决方案
@insympathy looks like you need a different connector or you could try to "rig it" but it would require some good soldering skills :-)
Here is what I get for the wires
If nothing else you get the USB-C pins from it:
Ground <==> pin 1
Red <==> Pin 9 VBus
White<==> Pin 7 D-
Green<==> Pin 6 D+
Blue<==> Pin 5 CC1
这个答案有帮助吗?
得分 4
7条评论:
Thanks man 🙏 ordered an additional set of 5-pin connectors that support fast charge. Will fix an older USB to Lightning for now 🙌
完成的
@insympathy That's the spirit!
Remember
REPAIR IS WAR ON ENTROPY.
Let's fix things and save our hard earned money.
完成的
Couldn't agree more 🙌
完成的
I have to replace the lightning end of a USB-C to lightning cable - what do I do with the blue wire? there only 4 pads on the replacement lightning tip and 5 wires. I have repaired several USB-A to lightning so I tried omitting the blue wire but no joy.
完成的
if you have a cable with 5 wires - you need a connector with 5 pins in order to support fast charging - those are also available on AliExpress
完成的
显示更多的2条评论
添加一条评论
添加你的答案
in_sympathy 将永远感激不已
浏览统计数据:
过去 24 小时: 21
过去 7 天: 133
过去 30 天: 600
总计 25,224
