跳转到主内容
加入维修社区 - 创建账户
惠普于 2015 年推出的第四代低成本 11.6 英寸 Chromebook 11。
How can I replace the storage?
If the internal storage is too low, what can i do to replace another large storage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @mbwilo_m
Short answer is you can't or not easily anyway.
According to the specifications the laptop has either 16GB or 32GB of eMMC storage.
eMMC storage is hard mounted onto the systemboard i.e. it is soldered to the motherboard
One option to consider is to insert the largest capacity SD Card that you can afford or want and insert that into the laptop's card reader and leave it there and use it for extra storage space.
这个答案有帮助吗?
得分 1
3条评论:
And couldn't the operating system be installed on the other colocated storage?
由完成的 分享
@davoc352
Probably not. Most likely the BIOS bootloader won't recognize the SD card port as a boot option.
由完成的 分享
i use window 11 lite on my chromebook hp g4 now it storage can upgrade from market place of laptop repair so if you dont have enough money you should buy this try to find 4gb ram is better because ram can't upgrade in someplace and currently iam using parrot os
由完成的 分享
添加一条评论
添加你的答案
Mishael Mbwilo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 1,914
