跳转到主内容
加入维修社区 - 创建账户
8 英寸 Amazon Fire HD 第八代机型于 2018 年发布。
How to fix charging port
Charging port needs repair
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
they are usually replaced using hot air, a soldering iron, solder and flux
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your answer but I really need step by step instructions on how to carry out the replacement. What tools I will need and stuff like that as well.
完成的
@johncam you would need a soldering iron with a small tip, a hot air station, flux and solder. https://www.youtube.com/watch?v=RlwB1Itz...
完成的
添加一条评论
If you don't have any experience (micro)soldering your best bet would be to find a replacement part if it isnt soldered on to the motherboard, if it is, you probably want to take it to a repair shop... Soldering a USB port with no experience is no easy job
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 585
