跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1700 个问题 查看全部
Power supply connector ripped off CUH-1206B
Hello! I messed up.
In the attempt of changing my PS4's (fat with physical buttons CUH1206B) thermal paste and pads, I ripped off the power supply connector in the motherboard. Below are some images.
The motherboard with ripped pads:
The connector:
The connector place in it's proper position on the board:
I have never messed with soldering, but I do intend to try fixing it as buying another PS4 is just impossible for me right now, so the simpler the solution, the better. I'm following other tutorials on this but I can't seem to figure out where the traces for the upmost left connector go, any ideas?
Thanks in advance, this console is very important to me and the moment I'm living.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
***arthurc.victor darn tore the solder pads off too. Well, you will need to solder some jumpers. See the attached image. You wil need to scrape the green masking off. Use a thin sharp object for that. I prefer a scalpel (available at plenty of places like hardware stores/feed stores and department stores). Then get yourself some enamel wire and solder the connection to the points on the board. Your connector will be pretty loose, I would use some good adhesive (no, not crazy glue) and adhere it to the board. Since you have never done this, practice on an old board first. It's not as easy as it looks :-) if you have never done it.
这个答案有帮助吗?
得分 1
5条评论:
Thank you for the help, but I have one doubt: the yellow dot would be ground? As in, just scrape the board and solder. And the purple line, should I solder to that square right next to it? Don't wanna risk frying the board, thanks again.
完成的
The red line, I’d just solder to the trace right next to it and not all that way. Neater too.
完成的
@strongbow i thought about that as well but went the path of least resistance. It’s a PITA to solder on that small trace :-) old eyes and shaky hands need a bigger connection point. ;-)
完成的
@arthurc.victor yes you can solder right on that pad. I just wanted to mark the general area for that
完成的
@oldturkey03 I'm thinking microscope so it would be massive lol. Which ever would be easiest to get it working again. 👍
完成的
添加一条评论
添加你的答案
arthurc.victor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 365
