跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,New Nintendo 2DS XL 是 2DS 掌机的技术改进型重塑机型。它是 Nintendo DS 系列的第九款,也是最后一款重新设计的产品。该主机比原始的 2DS 机型大得多,并增加了“New 3DS”系列升级版系统的所有功能,减去了在顶部屏幕上以立体 3D 效果玩游戏的功能。
Replacement Internal Screw Sizes
Does anyone know the sizes of the screws used internally? Several of mine stripped after using the wrong bit and I would like to replace them. I know there are replacement screw kits you can buy but they seem way overpriced.
I attempted to measure with my calipers but my measurements did not match common sizes. For example, the motherboard mounting screws measured at 1.33mm in diameter which is half way between the (what seems to be) standard M1.2 and M1.4.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
The 3DS XL and the 2DS XL use the same screws. You can easilly buy a screw kit for a 3DS XL for 5 bucks. Hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
Do you happen to know the screw sizes for the 3DS XL?
This would be good information to have as I have not found it documented anywhere. Plus, for $5 one can buy 100s of screws.
由完成的 分享
https://www.ebay.com/itm/184217821814 5 bucks is 5 bucks. Just take the easy route
由完成的 分享
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 37
总计 1,911
