跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
MacBook Pro charger gets hot when it starts charging.
Hello, please some one help me out.
My mbp's charger gets very hot when it starts charging. when the light turns amber, the charger connector becomes very hot. in order to use my mac i have to disconnect the charger so it cools down a little before plugging it in again. I opened it up, just to find out that the battery is swollen, and lately my battery doesn't last very long.
My theory: "The charger gets very hot because it is over working to charge the damaged battery reason why it get very hot, in conclusion the battery has to be changed".
However I'm not a pro and not sure of how viable my hypothesis is.
please somebody help me I'm really having a hard time with having to do my school work on my computer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Dre just based on this "just to find out that the battery is swollen, and lately my battery doesn't last very long." alone, replace your battery.
MacBook Pro(15英寸,带有Retina显示屏,2015年中旬)电池更换
MacBook Pro 15" Retina (Mid 2015) Battery
完成的
添加一条评论
1个答案
最有帮助的答案
The best way to diagnose what’s happening is using this gem of an App CoconutBattery the free version is all you need, but I do recommend using it to keep track of your battery’s health.
Post a snapshot of the main screen with the battery tab opened up while the system is under charged here for us to see.
In the meantime check your MagSafe socket for dirt preventing the cord to fully seat and the contacts are clean and shiny too.
这个答案有帮助吗?
得分 1
4条评论:
Hi Dan, thank for making out time for me.
I have updated the post with the image you requested for.
And I'd like to add that I also did a test with charger while the backed of the machine was opened, I disconnected the battery and tried to plug the charger, The indicator turned on "Green" them amber I let it plugged for like 1 hour but it didn't get hot like it does with the battery on.
完成的
@drec0xy - Yep! Time for a new battery. Batteries only last 4 to 5 years.
@oldturkey03 posted what you need. That should get you running.
完成的
Thanks Sir. I just hope the burning would go away after I do that.
完成的
@drec0xy - I’m sure it will.
完成的
添加一条评论
添加你的答案
Dre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 68
