跳转到主内容
加入维修社区 - 创建账户
Kia Soul 是一款由起亚生产并销往全球的前置引擎、前轮驱动的五门超紧凑型跨界车,目前已发展至第二代。
Keys do not work
My keys for my Kia Soul have been not working, I have to take out the spare key and unlock the car manually instead of being able to unlock from the key automatically. I have tried everything including re charging and giving the keys a bit of a break before trying again. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi
What is the year model of the vehicle?
Have you tried replacing the battery in the fob key?
Was the car's battery replaced just before the keys stopped working?
由完成的 分享
Hello, thank you so much for helping me! The year model is 2011, I did try and replace the battery and the battery was replaced after the key stopped working in attempt to try and work the keys again.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Hi,
Try to reprogram the key and see if that works.
  1. Get in the car and and ensure that all the doors are completely shut and then insert the key into the ignition keylock.
  2. Turn the key from off to on in the ignition repeatedly until you hear the door locks cycle. You should end the process with the key turned to the on position. The on position is not the engine start position, but where the key is when the instrument panel lights/gauges etc turn on
  3. Then try pressing the lock or unlock button on the key fob. If the doors respond by locking or unlocking (depending on which button you pressed), the key fob has been successfully reprogrammed.
  4. Turn the key back to the off position in the ignition. The door locks should cycle again, indicating the end of the programming sequence.
这个答案有帮助吗?
得分 1
3条评论:
My car dosnt have an ignition keylock it has a start button! I'm so sorry I should have mentioned that!
由完成的 分享
@Yasmin Queen
I don't know. You may have ask a Kia dealer.
由完成的 分享
I bought this kia soul 6 weeks ago. Loving it until I tried to start car tonight. Key won’t turn, steering wheel locked. There is a red circle around the starter. Doors unlock. This is key only starter. I am an 82 yr old lady and dealer is about 65 miles away. What can I try to get this to work ??Help!
由完成的 分享
添加一条评论
添加你的答案
Yasmin Queen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 47
总计 3,692
