跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Joy-Con 控制器的维修指南和信息。
Shell change, now no lights?
I have changed the shell and sticks on the joy cons ages ago following the guides and they both work perfectly except that the lights don’t come on anymore. I’m now trying to get into pairing mode to connect to an ipad and there’s no indication that it’s in pairing mode and the ipad is not recognising them. Any ideas? or do i need to get back inside the joy con?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi, Tayla.
Your problem is usual to others but Nintendo™ Already has a solution to this issue
这个答案有帮助吗?
得分 0
1条评论:
This doesn’t help me at all.
完成的
添加一条评论
If you recently changed the shell and no lights are coming on despite the the joy-con being charged, you may have damaged the ribbon cable to the SL/SR button board which also houses the lights. These seem to often be bent pretty severely and can break when you do any kind of repair work. I recently replaced this on three controllers I have and all work great now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tayla Hathaway 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 200
