跳转到主内容
8 inch tablet released in July of 2019. Came as a 32GB or 64GB model. The display is a TFT LCD with a resolution of 800 x 1280 pixels. Main Camera is a 8 MP camera and the selfie cam is a 2MP cam. The versions are: SM-T290 (Wi-Fi); SM-T295 (LTE)
The tablet does not turn on, when plugged keep bootlooping
when i plug it it turn on by itself display the samsung logo then turns off immediately
What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
gateway tech sounds like a power issue. I suggest that you start checking your charger, your charging cord and of course your charging port. Make sure that it is clean, no broken or bend pins and no debris in it. Use a USB ammeter to check how many amps your tablet is trying to "pull" . After that you want to go ahead and change the battery as well. Use something like this video as your guide. Once you did all of this and if you are still having issues, you may need to look deeper and start considering board level checks like suggested here
Of course, while you work on it, create a guide for the rest of us on here. It is not complicated and will be very helpful to the community. https://www.youtube.com/watch?v=j0WMP6vq...
这个答案有帮助吗?
得分 1
1条评论:
I'm having the same problem did anyone find the fix for this yet I also read on some forums to take off the back and unplug the battery or a min and plug it back in. I'm going to try the battery unplug method and I will comment to let anyone else having this problem if that worked.
完成的
添加一条评论
添加你的答案
gateway tech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 326
