跳转到主内容
加入维修社区 - 创建账户
Mavic Mini 支持 1200 万像素航拍照片和 2.7K 四倍高清视频。三轴机械增稳云台可提供出色的相机稳定性,确保影像清晰且超级平顺。这款四轴飞行器重量仅 249 克。型号:MT1SS5。
Help with lost mini resistor
Hi.
I managed to lose a mini resistor when I was replacing the gimbal cable after a crash with my DJI Mavic Mini...
Could you help me with the information about the resistor? It's the one on the outerside by the connector of the flat gimbal cable on the mainboard. I've attached a picture showing it.
Regards Lars Jonsson.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
Hi
Unfortunately I don't have board to take reading for that resistor however,if you have a multimeter we can do some tests to see if its necessary
what to do is put the metre into continuity mode and put one probe on the metal part of the metal shield(or the screw hole) beside where the resistor goes and press the probe onto the pads and see if it makes a beep noise, if it does there could be a chance that its not necessary as it could be connected straight to ground ,if that were the case you could solder a small piece of wire over the 2 pads
if it isn't connected to ground you will ether need a schematic or a donor board to get the part from
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lars Jonsson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 463
