跳转到主内容
加入维修社区 - 创建账户
The HP Pavilion 14m-cd0005dx is a touchscreen laptop designed by HP. It is 14.0-inches diagonal, with a 1366x768-pixel resolution display.
Guidance on Screen replacement
How much more difficult does “touch screen” function make replacement? Are there many more caveats to screen replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@eeandersen it is not much more difficult. You will just have a few more cables and connectors. Essentially the same work. You can download the maintenance and service guide for the HP Pavilion x360 14m-cd0005dx from here It'll guide you through the repair
这个答案有帮助吗?
得分 1
1条评论:
@eeandersen, On your laptop the touch screen function is integrated into the LCD display, so there isn't any separate part to deal with; in fact, you can't replace them separately. As @oldturkey03 mentioned, there will be one more connector to route and plug in for the digitizer, but that's it for the difference between replacing your display and a simple LCD replacement.
完成的
添加一条评论
添加你的答案
Eric Andersen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 211
