In need of a CM6400 any better places to find one?
Hi
I have been working on a blue yeti mic and have came to the conclusion that the CM6400 audio IC is the issue
https://www.cmedia.com.tw/products/USB20...
I have found many on AliExpress and I’m wondering if anyone can find any from anywhere else as AliExpress is saying it’s going to deliver mid march which is a bit long to wait
Any help is greatly appreciated
48条评论
@hellomacos give this guys a holler https://www.4starelectronics.com/part_de... Lets see if they are quicker.
由 oldturkey03 完成的
@oldturkey03
Thanks for letting me know about them
Iv just sent a request
Let’s see what they come back with:-)
由 HelloMacOS 完成的
@hellomacos just curious what issue do you have with the CM6400 ? I am also working on a Blue Yeti and already tried a whole bunch of firmware versions. I'm afraid I'm close to reaching the same conclusion as you..
由 io nut 完成的
@io nut
My issue is that the recording is very very faint and there LOADS of static or buzz in the recording,I came to the conclusion that the chip was at fault as I couldn’t find any shorts in the board and the noise still appears when the capsules/mics are disconnected
The CM6400 chip also gets noticeably warmer on the board I’m working on
The CM6400 seems to controll a lot of that sort of stuff from what is says on its data sheet:-)
由 HelloMacOS 完成的
@HelloMacOS
Hmm, well at least yours shows some signs if life..What hardware rev is printed on the boards? (one says yeti analog and the other says yeti digital, but the numbers should match). Also, do you know what firmware rev you have on it ?
由 io nut 完成的
显示更多的43条评论
