跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
TV screen is very dim after replacing new main board
So my aunts TV screen went out was the main board. So I replaced it and when I turn TV on your able too see the screen but it's very dim and when I adjust the brightness it doesn't seem to affect anything. I went thew some of these forms to diagnose the issue and found that possible the backlight board could be out what's the best way to troubleshoot this issue??
Its a RTU5540-B Rca
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@shingo87 yes, what you are describing sounds definitely like bad back lights. Two distinct possibilities. One being the backlight board, the other one being the backlight strips. Schematics for the boards are not available so it'll be hard to troubleshoot. I suggest you measure the voltage to the LED backlight strips. If the voltage is appropriate, it's your strips. If it is not, its most likely the board. Post some good pictures of all of your boards etc. with your question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 119
