跳转到主内容
加入维修社区 - 创建账户
你可以在下方找到 2020 年发布的 HP Chromebook 14a-na0000 系列笔记本电脑的维修指南、手册和故障排除建议。获取你需要的必要信息,自行维修你的 HP Chromebook 14a-na0000 系列笔记本电脑。
Chromebook hinge cover broken
I've had my Chromebook since June 2021, and a few days ago the plastic around the screen on the lower left (I think this is called the "hinge cover") broke, the bottom part detached from the screen (only at the left, not the entire thing) and eventually cracked completely off from the left side of the plastic. I didn't drop it, this just happened gradually I guess. At first I thought it was just cosmetic, but just now the screen flashed black for a second when I moved the computer - it isn't happening every time, in fact it hasn't happened again since, but I'm sure the issue will progress if I don't do something.
This is what I can see inside the plastic (if I angle the screen so it sticks out enough):
My question at this point is, if I made sure those little white parts on the outside were aligned right and pressed in real good, then used glue or putty or something to seal the plastic back up, would that prevent any more screen flashing or other issues with the screen itself? Can I even use those things on my computer? I don't know if the picture was clear enough, but I should be able to glue it without affecting the hinge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Hello,
The screen flashing is likely caused by the ribbon cable not being properly seated.
https://youtu.be/2FxhY7LK3tI
This video shows how to fully replace the screen, you're just looking for the ribbon cable shown at roughly the 1:34 mark, once that's fully seated, your screen flicker should be resolved and you'll be able to repair the hinge in any way you see fit!
If that doesn't do the trick let me know and we'll keep trouble shooting!
Coco,
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your answer. I haven't taken action yet (nervous), the state of the hinges has gotten worse (screen and keyboard only connected by wires at this point), but it's only flashed black one time since then, no matter what I do to it - it was when I was peeling at the bezel trying to tentatively get it all the way off, it lasted for like 5 seconds, and the Youtube video I had playing with sound PAUSED (not froze, actually paused) when it happened, making it seem like it was something the computer "did on purpose" and not just the screen failing. :/
由完成的
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Em 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 20
总计 1,120
