跳转到主内容
加入维修社区 - 创建账户
2014 年 4 月更新的 11" MacBook Air 搭载了焕然一新的双核 i5 和 i7 Haswell 处理器,电池续航时间略有增加。
Replacement SSD is not working
I replaced the SSD on my Early 2014 Macbook Air 11". The Macbook was running Big Sur, so the EFI firmware should have been up to date. However, the new drive does not show up in disk utility. Any recommendations how the issue could be diagnosed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What is the SSD you used to replace it?
由完成的
添加一条评论
1个答案
最有帮助的答案
If you are trying to use Internet recovery that won’t work as the macOS it is based on is the older version. You’ll need to swap it out with your original so you can setup a USB thumb drive as an OS installer using your systems Big Sur OS installer. First format the thumb drive to GUID Extended Mac. then follow this guide Create a bootable installer for macOS
Now swap over the SSD again and then use the installer thumb drive to first format the new drive and install the OS. The last step is migrating your stuff back from your backup.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
heikopanther 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 406
