跳转到主内容
加入维修社区 - 创建账户
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
Is it dangerous to turn on a eMac that hasn't been used in 5+ years?
Hi,
Just found a emac and is wondering if I should take any percautions before starting it up to see if it works.
Update (01/09/2023)
Sorry to bother again but I realized that the eMac is stored glass down with no towels. Is it still ok?
Sorry I'm just afraid as I don't want any damage to happen to it.
Thanks so much :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks so much :)
完成的
添加一条评论
2个答案
已选择的解决方案
@appleipodnano the only thing for now is checking the power cord. Make sure that it is not frayed or cracked due to age or weathering. Out of habit, I stand to the side of the equipment to check it and when I turn it on. Just old habits from some "interesting" devices I 've worked on. Otherwise, give it a try and let's see if it'll fire right up :-) Let us know if it turned on....
Update (01/09/2023)
@appleipodnano just in case you actually would like to troubleshoot or consider working on it you may want to look through these guides. The ESD safety Guide will be of particular interest to your personal safety ;-) EMacESD Safety Technician Safety We would need to know the exact model for your eMac to be more specific for the service guide. Enjoy it.
Update (01/09/2023)
@appleipodnano no problem. Yes, you should be okay. Of course, it all will depend on where it was stored. Any chance it may have gotten liquid into it? If unsure, then I would do it a bit different. Use the guide I've attached and just remove the rear housing. Then see what you are up against. Any corrosion, frayed wires anything, then wait and repair that stuff first. Post a couple of pictures with your QUESTION so we can see what you see. At this time you do not have to worry about the ESD safety etc since the device hasn't been plugged in for a long time. Of course, it is always good practice to not unnecessarily touching exposed wires or components, but you are safe on a piece that was unplugged for a long time. By now, it will be totally discharged.
Congratulations on being careful and conscientious. All good traits to have, to get things fixed right!
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
2条评论:
Tanks so much! I will try it soon :)
完成的
Where it is stored it is near impossible to get wet. I think im ok :)
完成的
添加一条评论
最有帮助的答案
Well … It’s safe to plug in to see if it works. But if you open it up you do need to be careful as you have some large capacitors and the CRT also holds a sizable charge. Each could hurt you or worse!
这个答案有帮助吗?
得分 2
1条评论:
Yeah I don't plan on opening it, as I read the other question about CRTs.
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 239
