跳转到主内容
加入维修社区 - 创建账户
2009年10月发布。可通过型号 m6-aq003dx 进行识别。
Hdmi Port not working.
Ok, I'ma try to make this as short as possible. The HDMI port on the computer itself isn't working with anything. Tried 3 different HDMI cables with two different display devices. I know the cords and display devices work cause I tried all 3 cables with a different laptop and everything works out fine. Tried "detect device" in the display settings menu but nothing. All drivers and software including windows is updated to the latest as of 12/27/22
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Go to Device Manager and on the list of devices check for any devices ending with an exclamation point and delete them. Now click refresh at the top left or collapse n uncollapse the libraery or simply Reboot your system. Do not worry, this will not delete any device this will refresh the drivers back to their normal state. all Device Manager Drivers are stored in your operating system and reloads them on a refresh or if deleted.
When u reboot make sure the cable is connected so your system picks it up.
if you are plugging to a tv or monitor,
you must let your system know by going into the Display window in Settings and checking off the Add secondary Display in this section you can also mirror or deside wich display should be primery.
Lastly Should the above not work,
Check your Cmos, The HDMI feature could be turned off there. if it is, Activate it and hit F10 on your keyboard, pad or screen board. Good luck!
这个答案有帮助吗?
得分 2
2条评论:
Thank you! Was able to get it working flawless after I did what you said, I even used it to make the computer accept a updated driver for the graphics aswell. Much appreciated 👍
由完成的
Thanks!!! Worked for me as well.
由完成的
添加一条评论
添加你的答案
Boosted Garage 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 35
总计 3,489
