跳转到主内容
加入维修社区 - 创建账户
Melitta 的小型全自动咖啡机。这些指南也适用于其他 Melitta 机型,以及 Nivona、Siemens 和 Miele 的全自动咖啡机——它们的结构非常相似。
Size of the grind
Hi,
I opened the Caffeo Solo for a cleanup and closed it back. Now when the motor grind, the size of the coffee grind is top big and the infusion is not happening. I tried to change the size of the grind, nothing changed.
Thks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Did you open the grinder? Follow this guide, open it and adjust it. This is a good opportunity for a replacement of the grindstones.
这个答案有帮助吗?
得分 1
5条评论:
Thks for the quick answer ! I'll try next weekend and let you know.
由完成的
I followed the tutorial but nothing changed. The size of the grind is still too big. I didn't see where to adjust so it might be that.
由完成的
I don't know why, but this part does not appear in the english translation:
Jura 研磨盘更换
由完成的
If you want to watch the grinder, when opened, use an empty toilet roll.
由完成的
I finally had time to unmount it and managed to fix it. The issue was that I did not screw properly the black ring (size selector) to the grinder. Thank you very much for your help.
由完成的
添加一条评论
添加你的答案
Romain 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 23
总计 953
