跳转到主内容
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
49 个问题 查看全部
Can I use a non oneplus battery on this oneplus 2?
Hello, I'm new to phone modding, and I wanted to know: can I use a battery from another phone on my one plus 2? I have a Motorola phone which has a broken screen, but the battery is just fine. I wanted to know if I can transplant the Motorola battery into my one plus 2.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@techblowhead I'd suggest that you do not try to solder on the battery etc. The specs for the battery may not be what your original battery would use. Remember that these are smart batteries. They use a controller board that enables the battery to actually communicate in a two-way fashion. I am sure that all of that could be overcome, but since batteries for your phone are still readily available, I would not take a chance of a battery to overcharge/undercharge etc. based on replacing a connector etc. That may have some disastrous results for your phone. OnePlus 2 Battery (ifixit.com)
OnePlus 2 Battery图片
产品
OnePlus 2 Battery
$19.99
这个答案有帮助吗?
得分 1
添加一条评论
Do they have the same connector? If they do, I guess you could. Since they are made by different companies on different phones, i wouldn’t expect it to work, but give it a try.
Hope this helped and merry Christmas,
Tay
这个答案有帮助吗?
得分 0
2条评论:
no, but I was thinking that I could take the connecter terminal from my one plus battery, and solder it onto the terminals on my Motorola battery. then i would just connect the battery to the one plus
完成的
I would just buy one that matches instead of going through the trouble of doing this @techblowhead
完成的
添加一条评论
添加你的答案
Techblowhead 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 39
