跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
A way to check new display?
Hello!!
I plan to soon replace my iPhone 4 screen for a color swap to red, Is there a way to just unplug the 2 ribbon cables that power the current screen and then just plug in the new one just to check it and make sure it works correctly? I would like to no because i do not want to tear the whole thing apart then put it back together just to see that the new display does not work correctly. I need help at this, can anyone maybe post direction's or maybe a link....please help,
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
It is possible, what you would need to do, the guide is here:
iPhone 4 (CDMA/Verizon) Screen Replacement
step 13 is removing the cover where the connectors are and the connectors are identified in step 15
the only issue I see is that if you don't remove the display assembly the 2 cables you will be unplugging and replacing may get in the way as they lift up and point out of the top of the phone, you can then plug in the 2 new connectors but will need to support the display assembly you are testing, turn on the phone, turn it back off etc.
good luck :)
这个答案有帮助吗?
得分 4
6条评论:
So is there any harm in doing this and how should i hold the new screen, also there is a cover on the LCD do i have to remove this to test the screen?
完成的
there really is no harm in doing it, hold the display however is comfortable just try not to put to much pressure on the back of the lcd itself to prevent damage, you're only really holding it to make sure that the cables don't get pulled on you might be able to rest the screen on something small and sturdy instead. You can leave the plastic bits attached to test the part I usually remove these during the fitting just in case you have to return a dead part.
完成的
The protector is plastic and it is one the back of the LCD,then I can plug in the new display and set it on something while testing it?
完成的
Yeah that sounds right, I would leave the plastic protectors on both sides whilst testing incase you receive a dead part, all you need to ensure is you don't pull on the digitiser & LCD cables :)
完成的
Thank you for all your help:)
完成的
显示更多的1条评论
添加一条评论
添加你的答案
kaine 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 479
