跳转到主内容
加入维修社区 - 创建账户
Dyson AM10 加湿器的维修与拆解信息。
What does a Piezo do?
My AM10 has stopped misting, doesn't draw any water from the tank.
I am trying to troubleshoot it.
First stop is something called a PIezo, which is accessed from a panel on the bottom of the base unit.
my looks to be in poor condition but I don't know if it is the source of the problem. in fact I don't even know what it does.
it appears to have a watertight seal. so it must be sitting at the bottom of the water tray.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
@pjstock, A piezo is basically a “speaker” or more commonly known as a buzzer.
I say “speaker” because because it’s not playing sounds as a speaker, it’s only really capable of producing tones in given ranges.
You can Google “piezo buzzer” if you want to read and understand more about it :)
这个答案有帮助吗?
得分 2
添加一条评论
Google it. Loads of different types.
这个答案有帮助吗?
得分 1
添加一条评论
Hi. I have the same issue with my am10. Have you found a solution?
Thanks! I’d appreciate it!
这个答案有帮助吗?
得分 0
1条评论:
change it will help. I also have the same problem and find it in amazon https://www.amazon.com/dp/B0BWN3BZR8
由完成的
添加一条评论
I think in this device working the piezo element not like speaker but like object size detector. Same like in dyson vacuum cleaner. Small pieces hitting the piezo, thats generate a very small current, from this currend is calculated how many and how big pieces was catched.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue . No mist anymore . I changed the piezo but it did not help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
peter stock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 36
总计 1,611
