跳转到主内容
加入维修社区 - 创建账户
Intel 旗下专注于游戏领域的 Skull Canyon 系列 NUC。
Question identifiying SMD Component - Capacitor?
Hello everyone, I have a question that I posted on Reddit and got a few contradicting answers. I purchased this Intel NUC6i7KYK as "Parts" on eBay because it was power cycling. I originally thought it just needed some cleaning and new Thermal Paste, but that is not the case. I was looking at the bottom of the board, and found what I believe to be a blown capacitor. I attached a stock picture, and circled the component in blue. I know it is impossible to identify the exact specs of this part, but at least knowing what type of part it is will point me in a direction to troubleshoot. Since the board is dead, I really have nothing to lose by trying to fix it and learn from it. According to Reddit, it is either a fuse, capacitor or resistor. One suggestion would be to put a 0ohm resistor in and try it, but I don't want to do that if it is actually a capacitor. Thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Looks like a resistor, the caps are a browny colour. I’d try and find a resistor the same dimensions and try it. Remove it from the board first and see if there’s any measurement across it. I’d also check for a bad mosfet.
这个答案有帮助吗?
得分 3
2条评论:
Perfect, thank you very much for the quick reply!
由完成的
I think it is a ferrite bead, used to filter out noise from the power line. See for more information:
https://www.analog.com/en/resources/anal...
由完成的
添加一条评论
添加你的答案
Likwid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 37
总计 776
