跳转到主内容
加入维修社区 - 创建账户
第七代 Apple iPad (Wi-Fi 版) 的维修指南、拆解及故障排除信息,提供 32 GB 或 128 GB 存储容量。于 2019 年 9 月发布。型号为 A2197。
Screen ghosting/Shadow on Led.
I cleaned the lightning port with electrical contact cleaner, worked great.
now the LED screen appears to have some ghosting/shadows behind the image. never had this issue before.
Is this fixable? or do i need to replace the LED.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Oliver,
Depending on how heavily you doused the port with the contact cleaner, it's possible some of it made its way inside and got onto the LED/backlight/polarizer assembly. We've seen cases where a similar thing happened with isopropyl alcohol, and luckily after a couple of days the alcohol finally evaporated and left the screen okay.
In your case I'd suggest giving it some time to allow for the cleaner to dissipate; it may fix itself all on its own. If it still looks like that in a week then it might be worth considering a screen replacement.
Let us know what happens; if it doesn't clear up on its own, add some pictures to your question of what you're seeing and we'll see what we can do for you then.
这个答案有帮助吗?
得分 1
添加一条评论
The first thing you should do if you're dealing with the ghost touch issue is to force restart your device. This will refresh the memory and reload all services. Needless to say, it brings your iPad back to its normal operation.
Regards,
Will
这个答案有帮助吗?
得分 -1
1条评论:
@willjoe it’s not a touch issue it’s an image issue.
由完成的 分享
添加一条评论
添加你的答案
Oliver Byrne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 568
