Why is my Sony wh-1000xm5 not charing?
when I first got it, it used to charge with just any usb-c cable.
about a month ago it'll only charge on original usb-c.
now it'll not charge with anything.
charging light still turns on, and will be on for hours without charging.
sometimes I get lucky and it actually charges to 100% and battery life seems normal.
everything else works fine.
what could be the problem? Did I break it?
Hi Igor,
I have the same issue. Have you managed to fix it?
Thanks,
F
由 Flavius A 完成的
Hi, I had to contact sony. Luckily the warranty was not expired. They ended up sending me a brand new pair. I sent my broken pair back to sony.
由 Igor Jin 完成的
