跳转到主内容
The RIDGID R84015 X2 is an 18v, 1/2 inch chuck, cordless drill.
4 个问题 查看全部
full speed or nothing at all
i had the drill for 3 months and all of a sudden i lost my variable speed. I would like to know if its just a trigger switch that needs to be replaced or something else. if u pull the trigger its all or nothing can u help me please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
rob, sounds like your switch needs to be replaced. "switch handles all on/off and variable speed functions. They also have a role in electric breaking; they can momentarily reverse electrical polarity. Because switches use mechanical internals, they tend to degrade and wear out over time, eventually requiring replacement. Some common signs of a broken or failing switch are:
The tool will not start when you use the switch, or it requires multiple tries to turn on, until eventually it refuses to start at all.
The variable speed function and electric braking aren’t working properly." this and a new switch from here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
where to get switch& instruction.
完成的
chrisjcgibson669 for a new switch follow the link in my original answer. Still available :-) For the How-To follow the guides on here RIDGID R84015 X2
完成的
添加一条评论
添加你的答案
rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 1,053
