跳转到主内容
The Hisense 32H4C model is a 32-inch high-definition television with a light-emitting diode (LED) display.
Won't turn on and light is off
hisense smart TV won't turn on. The red light underneath the TV is off as well.
How can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
Have you checked that the power outlet that the TV is connected to is working?
If connected to a powerstrip (power board) connect it directly to the wall outlet and check if the red light turns on
Was there a storm or power outage just before the TV stopped working?
Please confirm the model number of the TV?
完成的
添加一条评论
1个答案
First plug in the outlet another device to see if the outlet is functional.
Then check with a multimeter (continuity test) if the cable is OK.
If the cable is fine, then most likely the problem is in the power supply
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Montseng Bereng 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 69
