跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
427 个问题 查看全部
Reverse lights inoperable, any help?
2001 Honda Accord LX, Automatic Transmission, 3.0L V6.
A while back my Speedometer lights would not illuminate and my reverse lights would not turn on. Since I replaced the Dimmer Relay fuse in the engine bay, my speedometer gauge lights work but my reverse lights are still not operating. The bulbs are new and no connections seem to be corroded, I’m just wondering if there is a fuse I missed!
Thank you for your time!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Ryloo should be #9 fuse in your driver's side fuse box. It is not a dedicated fuse, but other things are connected to that as well. There is also a relay for the back-up lights in the same fuse box. You should here it clicking when you place your care in reverse.
The other issue could be a failed or misaligned backup light switch. On your automatic transmission, the back-up light switch is part of the gear position switch, located on top of the transmission. There is also a reverse relay in the driver's side fuse panel.
这个答案有帮助吗?
得分 2
1条评论:
That sounds perfect, thank you so much! I’ll let you know what progress I make!
完成的
添加一条评论
添加你的答案
Ryloo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 299
