跳转到主内容
加入维修社区 - 创建账户
华为 2017 年的旗舰智能手机,于 2017 年 3 月发布。采用一体成型机身设计,配备与徕卡(Leica)合作开发的后置双摄像头系统。提供 32/64 GB 存储空间选项及六种不同的外观配色。型号包括 VTR-L09、VTR-L29、VTR-AL00 和 VTR-TL00。
Problems with Bluetooth audio
Since I replaced the display, the Bluetooth has been malfunctioning. When I put on the Bluetooth headphones, the device connects, but there is no sound. I would like to ask if this has ever happened to you and which component needs to be replaced. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If Bluetooth is turned on and the driver is up to date but your device still doesn't work, try removing the device and re-pairing it. Here's how: Go to Start , enter Devices, select Bluetooth and other devices settings > select the device > Remove device > Yes. Try pairing again.
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Massimo Piras 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 255
