跳转到主内容
加入维修社区 - 创建账户
Meeting Owl Pro 是一款专为协作会议通话设计的 360 度摄像头、麦克风和扬声器系统。
How to replace camera
I have an Owl Meeting Pro that fell off the table and now the camera is broken. The top dome appears undamaged but something in it is broken. The camera picture is mostly blurred/black. Its this something that can be repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
1个答案
最有帮助的答案
Hi Caroline. I know its been a while and my answer will probably not be helpful to you at this point. When the Owl webcam falls off (because most of its weight is in the top, so it is easy to tumble), it often breaks inside the lens. The fisheye lens is built like a cone or a mushroom and it will break where the lens comes inside the cone to each the camera sensor.
That being said, there is no replacement lens available (well, at least not documented). The only workaround is to find a donor webcam from which you will get the lens (and the camera sensor if needed) and "transplant" it to the webcam you are trying to salvage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
caroline work 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 67
总计 1,929
