跳转到主内容
加入维修社区 - 创建账户
2012 年首次发布的 MacBook 产品系列第二代磁吸交流电源适配器。与上一代系统不兼容。提供 45W、60W 和 85W 版本。
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
这个答案有帮助吗?
得分 6
16条评论:
So the output from both Power pins must be around 20V?
I have 85W charger.
由完成的 分享
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
由完成的 分享
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
由完成的 分享
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
由完成的 分享
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
由完成的 分享
显示更多的11条评论
添加一条评论
添加你的答案
Yurii Chaikovskyi 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 32
过去 30 天: 147
总计 13,568
